I removed the tracking pixel column in the view but it then just moves the icon into the subject field. How do you completely remove it? I just find it distracting and I already block trackers with a dns blacklist. Thanks.
btw if you have any other tabs open to emclient.com you get a ton of popup messages when creating a topic here.
I don’t think you can remove it from appearing in the email subject line (only the column) as eM Client is designed "to show the user if the senders email has tracking in it. So its a visual way to tell you.
Sounds like you might have some sort of possible eg: spyware in your browser causing the popup messages you are describing as i never get any popup messages like that when creating a topic.
