Trying to add the “To” field to the column view in a search folder - does not seem to be there, but the “To” is there when looking at individual sent folders per account. I am using a search folder because i want to see all sent mail from both accounts in the same view, but I need the To field to show as well. How do I accomplish this?
The TO column is for Sent folders only, so is only available on your actual Sent folders. The Search folder is a hybrid type of folder so won’t show it by default.
You need to disable conversations using Menu > View > Conversations > Disable Conversations. Then try the column configuration again.
I disabled conversation and now I have the “To” in the search folder. Can I turn on Conversation view by folder or is it on/off only?
It is either on or off globally.
