hae a few theme s i have created and now cant locate them on drive in order to delete them…where saved?
C:\Users\yourusername\AppData\Roaming\eM Client\Themes.
You can also highlight the theme in Menu > Settings > Appearance > Themes, and hit the Delete key on your keyboard.
Themes are kept there? I have no such folder on my PC but a perfectly functional version of EM Client.
First, you need to enable hidden items in Windows Explorer to get there.
Then, if you haven’t created and imported any custom themes, you won’t have that folder.
Also, if you are using the MS Store version of eM Client, the database is saved in a different location.
You can find the database folder location in Menu > Settings > General > Storage.
My PCs are permanently set to show hidden files. There is no C:\Users\yourusername\AppData\Roaming\eM Client\Themes folder on my PC UNTIL I import new themes. Interestingly, your suggestion takes me to C:\Users\yourusername\AppData\Roaming\eM Client
