Hi, can anybody help with a theme question. I am trying to set the background similar to the photo. It seems to be working when I select some messages but others are all white - not sure why?
Does anybody know which setting is causing this?
lunes 13 diciembre 2021 :: 2213hrs (UTC +01:00)
Hi @Mike_Pugh
This is governed by a combination of a number elements you can select here:
Menu ->Settings ->Mail ->Read ->Preferred Style
You make adjustments here to suit your preference
Skybat
[email protected]
