Theme editor default to current theme
I’m not sure if this is a bug or not, but when opening the Theme Editor from Menu > Tools > Theme Editor, it doesn’t default to the current custom theme I’m using. This has lent me to multiple times accidentally overwriting a custom theme I spent hours making (thank god for file version control).
If not a bug, can this become a new feature? Thanks!
jueves 06 julio 2023 :: 1847hrs (UTC +0100)
When you open the editor as an overlay to your eMC, you will see in this image:
use “pick element” to select the area of YOUR eMc you want to edit.
I suggest you make a few trial attempts, you can also select a particular Theme by using OPEN and navigating to the Theme you want to edit.
Trial & Error…
If you really know what you are doing you can edit the Theme XML file for even more control.
There are also user created Themes here for Free download…
USER THEMES
skybat
¡Suerte!
¡Los mejores desde Madrid la soleada y mantente a salvo!
Sie können auch Hilfe bei der Auswahl der Theme-Farben erhalten von
Themes Hilfe Es war eine große Hilfe für mich.
Torsten
Thanks for the replies but my issue isn’t how to edit colors, but that the user navigation path of Menu > Tools > Theme Editor does not automatically apply to the current theme.
This does work when first going into Settings > Appearance > Themes > Click custom theme > Theme Editor
I would suggest the UX when opening the Theme Editor should always default to the current applied theme. Unless this is a bug and I failed to convey the issue in the original post?
domingo 09 julio 2023 :: 1954hrs (UTC +0100)
I assume that this is the way that the software intends, if you think differently you should post a Feature Request, then if sufficient users request this it might be considered.
I believe that this is correct and would apply to any Theme selected.
If I am not correct I am sure someone will say.
skybat
¡Suerte!
¡Los mejores desde Reino Unido y mantente a salvo!
I thought I posted this as a feature request? Sorry if not done right, first post and new EM user :slight_smile: Let me know if there’s a different way to tag it.
martes 11 julio 2023 :: 0836hrs (UTC +0100)
Sorry, my mistake, I did not read all you put correctly.
skybat
¡Suerte!
¡Los mejores desde Valencia la soleada y mantente a salvo!
