The input is not a valid base64 string as it contains a non-base 64 character more than two padding characters, or an illegal character
Get the below error message when trying to send and receive e-mails… the input is not a valid base64 string as it contains a non-base 64 character more than two padding characters, or an illegal character among the padding characters
Please try deleting and re-adding your account, make sure you SMTP settings are correct.
Hope this helps.
Dave
I did remove and then re-add the problem account. The problem still exists trying to send or receive email. It says “The input is not a valid Base-64 string as it contains a non-base 64 character, more than two padding characters, or an illegal character among the padding characters.”
The second email account, which is set up identically sends fine. I am ready to uninstall emClient and go to Thunderbird.
Hi @Alibaddy
Sorry about the trouble. Since your second account works fine with the same setup, the problem is specific to this account, so it should be fixable. The error text alone doesn’t tell us where it comes from, so we need the detailed logs:
  1. Go to Menu > Settings > Advanced > Logging.
  2. Click Clear Logs.
  3. Under the affected account, tick IMAP and SMTP (or POP3 if that’s what the account uses).
  4. Save and restart eM Client.
  5. Reproduce the problem (try to send and receive).
  6. Send us the logs with the send button in the same Logging section, and tell me the exact time the error appeared.
Please also tell me your eM Client version (Menu > Help > About) and who your email provider is.
With the logs we can see which step the error comes from. Please hold off on switching to Thunderbird until then.
I just installed emClient and imported folders and settings from Outlook.
Receive works but puts all messages in Trash, and send gets that base 64 message.
Hi @vmit03,
Thanks for the details. There are two separate things here, so let’s look at both.
1. Sending fails with the Base-64 error
The error text alone doesn’t show which step it comes from, so we need the detailed logs:
  1. Go to Menu > Settings > Advanced > Logging and click Clear Logs.
  2. Under the affected account, tick IMAP and SMTP (or POP3 and SMTP if the account uses POP3).
  3. Save and restart eM Client.
  4. Try to send a message and to receive new mail, and note the exact time of the error.
  5. Send the logs with the send button in the same Logging section. Please put the link to this topic in the description, so we can find them.
  6. Untick the modules again afterwards.
2. New messages go to Trash
Please tell us in which folder the new messages show up (Trash of this account, or another Trash folder) and whether any rules are listed in Menu > Rules…
Please also let us know your eM Client version (Menu > Help > About), your Windows version, your email provider and whether the account uses IMAP or POP3.
Please don’t post logs or screenshots with personal data here in the topic.
eM Client Team
