The body of my emails will not show - Mac
Added English as an app-language in System settings. This was the latest addition to knowledgebase. Tried rebooting, kept language setting in the app itself in English and even removed all language specific spell checker settings. Still not working…
i tryed the read first there there was more text in terminal then i have tryed in terminal the one u write /application/eM Client.app… nothing there?
i then tryed the defaults delete then all text gone i then started eM Client and not it now only show this in terminal
HighestAllowedVersion = "9.9.0.0";
NSFullScreenMenuItemEverywhere = 0;
NSViewUsesAutomaticLayerBackingStores = 0;
WebKitCacheModelPreferenceKey = 1;
WebKitDefaultTextEncodingName = "UTF-8";
WebKitDeveloperExtras = 0;
WebKitTabToLinksPreferenceKey = 1;
WebKitWebSecurityEnabled = 0;
when click on replay i can see message but only there
u find in Language & Region
I think this was the same problem when eM Client update from 6 -7 or 7-8 not sure but one of them was same problem, and it is the Language on ur MAC need to be on English :frowning:
when u set it to that and restarted ur MAC then eM Client works even the eM Client still is in ur own Language so i hope eM Client get this issue fixed fast.
but now my email works and happy again, i tryed some others and i not like them coz some when they get the mails they removed them from internet so if u have the mails on phone then they gone there too and u not make it to see them there…
Thanks for a best email program :slight_smile:
I emails are removed, that sounds like it’s using POP3 instead of iMAP … :thinking:
it depends on what email u have if it´s gmail or yahoo or etc…
but problem i think is many have the program and there MAC is in other Language then english, i had my in Norwegian but when i set it to english my eM Client worked as should again and it is still in the Norwegian language but my MAC System is in english if i put it back to norwegian eM Client will do same and not show my mails… just hope they fix the problem fast …
Solved!
When the whole system primary language is changed to English, the eM Client will show messages as it should. Didn’t try changing it back to Finnish, but maybe you should look into this…
yeah then it works as should…
If u try changing it back to finnish, i can tell as i have write in my other post, it will go back and do what it is doing now with NOT SHOW again then ur back again to start where it not working again…
i had my system in Norwegian but can´t put back until they get that problem fixed …
