Have a very old thebat with huge database (>60gb) on the local NAS. TheBat has portable installation. How to import all of this?
You can either try the eM client import through File>Import>Import from The Bat, or if The Bat supports export into EML files you can import those through the Import window as well or simply drag them into the program.
