I am using an gmail-account with all functions. making a new Termin in calender doesn`t work. the Termin will be not created. what is the error? is it google or in em-client?
Hello Ulf,
We’re sorry for the inconvenience but we’ll unfortunately have to ask for more details. Could you please describe how exactly do you make an event (Termin)? What happens when you try to create it? Does nothing happen? Does the event appear for a bit and then disappear?
Are you getting any errors/messages? If it is so, could you please post a screenshot of the messages/errors that the program displays and also the log from the tab Log in the Operations window (Menu->Tools->Operations)? Just select all with Ctrl+A and use Ctrl+V to copy it here.
Also please include the number of the version that you use (Menu -> Help ->About).
Maurice
