Tasks columns configuration is not loading
Tasks columns configuration doesn’t load by default, but saved so one can open columns configuration dialog, click OK and everything is back.
can I ask you if you can describe more accurately what problem are you having? for example what steps lead to your problem.
regards
Jan
Sure!
In the tasks window, there are table columns. You can customize these columns and choose which of them you want to show or hide.
The problem is - when you exit the program, then open it again, the custom configuration is not loaded, but the default one. The funny thing though, when you open the columns configuration window again, you can see your configuration, so all you need to do is click OK and your configuration is back again (until the next program restart).
this is definitely bug we haven’t seen for a long time, Anyway they are supposed to be exactly as you have set up them even without setting as default.
Try to update to this version and let me know if it helps.
http://www.emclient.com/dist/v5.0.183…
regards
Jan
