I’ve just installed eM Client 5, set up to use my iCloud account. Mail and Contacts synchronized ok but Tasks did not. In the ‘accounts’ ‘calendar’ tab, there is no default folder for Tasks or Reminders. Can you help?
There was issue with iCloud, if you haven’t already then please install this version http://www.emclient.com/dist/v5.0.194…
Jan
Thank you Jan. That fixed the problem.
Lino
you are welcome.
Jan
Hi Jan,
I’ve noticed that after the installation there was a popup window that asks to “set program associations”. Do I need to check off any of the boxes? None are checked at this time.
Lino
This is for users who are having troubles setting eM Client as default email/calendar/contacts program, if you will uncheck those boxes you will cancel eM Client being default for that association.
Jan
Thanks again, Jan. I appreciate your knowledgeable and quick reply.
Lino
you are welcome
Jan
