How can I change the task background color in calendar view? Have tried everything, but stays blue regardless of theme, calendar color or category.
eM Client 6.0.22426.0, Win7x64, vanilla install
Hello Frank, unfortunately Tasks background color in the calendar can not be changed as Task’s folders do not include color coding on the server nor in eM Client, blue is unfortunately the default color.
Hello Paul, then I would recommend to change it to white/transparent or make it adjustable by theme, because blue is quite distractive and the contrast to the colored task category label is not so good.
Thanks in advance.
Thank you for the suggestion, we’re currently working on a new release that will feature a graphic re-design, we’ll consider improving this with future releases.
