System-wide Simple MAPI failure with eM Client Pro on Windows 11
a { text-decoration: none; color: #464feb; } tr th, tr td { border: 1px solid #e6e6e6; } tr th { background-color: #f5f5f5; }
Onderwerp: System-wide Simple MAPI failure with eM Client Pro on Windows 11
I am experiencing a persistent Simple MAPI failure on Windows 11.
Symptoms
  • Windows Explorer → “Send to → Mail recipient” does not work.
  • Microsoft Word → “A MAPI error occurred: Unknown error”.
  • LibreOffice/OpenOffice shows similar MAPI-related errors.
  • Tungsten Power PDF cannot send email attachments.
  • mailto: links work correctly and open eM Client.
Environment
  • Windows 11 24H2
  • eM Client Pro 11.x
  • Office LTSC Professional Plus 2024 (64-bit)
  • Previously had Outlook Classic installed
Actions already performed
  • eM Client completely removed and reinstalled.
  • Thunderbird tested (same behavior).
  • New Windows user profile tested.
  • SFC /SCANNOW completed successfully.
  • DISM /RestoreHealth completed successfully.
  • Windows repair installation completed.
  • Office completely removed and reinstalled.
  • Outlook removed.
  • fixmapi executed successfully.
Registry checks
Mail client registration appears correct:
HKLM\SOFTWARE\Clients\Mail\eM Client
HKLM\SOFTWARE\WOW6432Node\Clients\Mail\eM Client
Values present:
DLLPath
DLLPathEx
SupportUTF8
MailClient.Mapi.dll exists and is accessible.
MAPI findings
assoc .mapimail
returns:
Plain Text
.mapimail=CLSID{9E56BE60-C50F-11CF-9A2C-00A0C90A90CE}`
However:
ftype MAPIMail
File type ‘MAPIMail’ not found or no open command associated with it.
The following CLSID exists and appears intact:
HKEY_CLASSES_ROOT\CLSID{9E56BE60-C50F-11CF-9A2C-00A0C90A90CE}
including:
InProcServer32 = %SystemRoot%\System32\sendmail.dll
DropHandler present`
Request
Could you please advise whether eM Client relies on an additional Simple MAPI registration that may be missing, or whether the missing MAPIMail file type handler could explain why all Simple MAPI applications fail while normal mailto: functionality continues to work?
The new eM Client 11 MSIX packages use system support for redirecting Simple MAPI calls into packaged applications. The relevant registry keys are these ones:
Neither HKLM\SOFTWARE\Clients\Mail\eM Client nor HKLM\SOFTWARE\WOW6432Node\Clients\Mail\eM Client is relevant anymore.
.mapimail is not in any way related and it’s not our registry keys.
I cannot really advise what to check next. The default value in HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Mail should be PackagedMail. The default value in HKEY_CURRENT_USER\Software\Clients\Mail can be deleted, especially if it’s set to eM Client.
