While trying to add new Gmail account it endlessly return to reauth. Got this logs from the auth journals (see the topic).
Version of the emClien: 9.2.2307
Hi @akosta66,
Thank you for the report. No log came through in the topic, and please don’t post logs here, as this is a public forum. To find out why the Gmail sign-in keeps coming back, please send us the logs like this:
- In eM Client, open Menu > Settings > Advanced > Logging and click Clear Logs.
- Under the Global modules, tick Authentication. If the Gmail account is already listed there, also tick IMAP and SMTP under it.
- Save and restart eM Client.
- Try to add the Gmail account again and note the time when it goes back to the sign-in.
- Send the logs with the Send Logs… button in the same Logging section and write the link to this topic in the description.
- Afterwards, untick the modules again.
Please also tell us here:
- your Windows or macOS version,
- how you add the account: with the automatic Gmail setup (Google sign-in) or manually with IMAP,
- at which step the error “The input is not a valid Base-64 string” appears, and whether the Google sign-in page itself finishes without an error.
eM Client Team
I’m afraid sending You logs with Authentification as I see there login tokens for my accounts.
Anyway:
- Windows 1022H2
- automatic Gmail setup
- the error “The input is not a valid Base-64 string” appears after he Google sign-in page itself finishes without an error but nothing happens in GUI and still the button Finish (which relaunch the auth process).
