System.Data.SQLite.SQLiteException (0x80004005): out of memory
Hello!
Every time I run eM Client, the following error appears after 10-20 minutes:
eM Client (6.0.22336.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.34209
I have tried to reinstall the app, but it doesn’t help. Please advise.
Hello Pavel, what mail service are you using with eM Client? Are you able to load the application in offline mode?
To run the application in offline mode hold down the CTRL button while you click on the application and hold it until the application finishes loading.
Thank you.
I’m getting the same error. Program seems great otherwise, but it’s very distracting. I’m running Windows 10 with 64 GB of RAM. Am trying offline mode now…
Hello Robert,
after you test the offline mode, can you please copy the error message from your device as well?
Here’s the Log entries around the time of the last error (I am running in offline mode right now):
9:14:56 AM [email protected] [Exchange Web Services] Synchronizing folder ‘[email protected]/Personal/’
9:14:57 AM System.Data.SQLite.SQLiteException (0x80004005): out of memory
9:14:57 AM out of memory
9:14:57 AM at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
9:14:57 AM at System.Data.SQLite.SQLiteCommand.BuildNextCommand()
9:14:57 AM at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
9:14:57 AM at System.Data.SQLite.SQLiteDataReader.NextResult()
9:14:57 AM at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
9:14:57 AM at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
9:14:57 AM at System.Data.SQLite.SQLiteCommand.ExecuteDbDataReader(CommandBehavior behavior)
9:14:57 AM at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader()
9:14:57 AM at MailClient.Storage.Data.DbRepository1.FindEnumerable.d\_\_8.MoveNext() 9:14:57 AM at System.Linq.Enumerable.d\_\_31.MoveNext()
9:14:57 AM at System.Collections.Generic.List1..ctor(IEnumerable1 collection)
9:14:57 AM at MailClient.Storage.ItemEventArgs1..ctor(IEnumerable1 items)
9:14:57 AM at MailClient.Storage.ItemEventArgs1.FromList[S](IEnumerable1 items)
9:14:57 AM at MailClient.Storage.Data.DbRepository1.RemoveByItems[ST](Object senderContext, IEnumerable1 items)
9:14:57 AM at MailClient.Storage.Data.DbRepository1.Remove[ST](Object senderContext, IEnumerable1 items)
9:14:57 AM at MailClient.RepositoryExtensions.Remove[T,ST](IRepository1 repository, IEnumerable1 items)
9:14:57 AM at MailClient.Storage.Attachment.Data.ItemWithAttachmentRepositoryAdapter1.InnerRepository_RemovingItems(Object sender, ItemEventArgs1 e)
9:14:57 AM at MailClient.Storage.Attachment.Data.ItemWithAttachmentRepositoryAdapter1.Remove[ST](Object senderContext, IEnumerable1 items)
9:14:57 AM at MailClient.Protocols.Common.ItemSynchronizeContext2.RemoveItems(IEnumerable1 obsoleteItems)
9:14:57 AM at MailClient.Protocols.Common.ItemSynchronizeContext2.Synchronize[T](SynchronizationType synchronizationType, IEnumerable1 items, Func2 getUniqueId, Func3 hasChanged, Func2 isDeleted, Func2 convertItems, Action2 updateItem) 9:14:57 AM at MailClient.Protocols.OfflineAddressBook.OabContactSynchronizer.Synchronize(IItemSynchronizeContext1 synchronizeContext, Folder folder, CancellationToken cancellationToken)
9:14:57 AM at MailClient.Protocols.Common.ItemSynchronizer`2.<>c__DisplayClass28_0.b__1(WorkerStatus status, CancellationToken cancellationToken)
9:14:57 AM at MailClient.Protocols.OfflineAddressBook.OabGenericCommand.Execute(WorkerStatus status)
9:14:57 AM at MailClient.Commands.Command.Process(WorkerStatus status)
I should add that the program seems to be working fine. The only problem is that the error notificaiton keeps popping up. Also, I am running on an SSD. Perhaps it has some kind of disk checking going all the time? I noticed that in another thread it was said there was an issue with defragging software.
It keeps doing this every few minutes. It seems to happen when checking Exchange Web Services, but not Gmail.
Hello Robert,
after this issue pops up please go to C:\Windows\SysWOW64 in your computer and run Taskmgr.exe
Right click the eM Client task and create a memory dump file.
Send the file to [email protected] with a link to this forum.
An .oab file located in your database would be useful as well (the name of this file can vary as it’s random, but it should be the largest file with an ‘oab’ suffix)
Hello
It ́s impossible to run Em client, the following message/error appears:
System.Data.SQLite.SQLiteException (0x80004005): disk I/O errordisk I/O error
   at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
   at System.Data.SQLite.SQLiteConnection.Open()
   at MailClient.Storage.Data.DataStore.GetConnection(String relativeName)
   at DbRepair.CorruptionChecker.CheckCorruption()
   at DbRepair.FormCheck.Check(Object state)
Andre
