Syncing Updated Contact: specified method is not supported
  1. New message > start typing an email address
  2. Email address appears in drop down so I select it
  3. I want to add a name to associate with the email address so I right click and select “Edit Contact”
  4. I enter a name > save & close
  5. Soon after I get an error notification “Uploading item(s) to folder ‘[account]/Other Contacts’ failed due to the following error: Specified method is not supported.”
Other contacts is a special Gmail “Read Only” folder that “you can only edit online” via your browser. They are contacts that have never had a contact name associated to them.
So go online to the following Google Contacts Other contacts page, and then “on the far right of the contact” hover your mouse and you will see a “Save Contact” icon appear which will then add it too your main Google Contacts Folder which you can then edit in eM Client after you either close and reopen eM Client or click “Refresh” in eM Client to sync the online changes.
“Google Other Contacts”
https://contacts.google.com/other
Thank you!!!
