synchronization problems
Since a couple of weeks the number error messages increases. There are error messages. One is as follows:
"An error occurred
Uploading items to folder /user email/contacts/ failed due to the following error: execution of request failed: https://www.google.com/m8/feeds/contact/user email/full/454029b8aed3028 contact not found)"
The other is shorter:
"An error occurred
Synchronization error (SyncStateNotFound)"
It seems to me that the contacts in Google Contacts are only in part recognized by eM Client. When in Contacts in eMClient I make changes to an existing contact, the error message usually occurs. Also if I add a contact in Google Contacts it is not always synchronized with the contacts of eMClient.
Perhaps it’s a problem of how you store names of contacts? In Google I only have to fill in the name of the contact, such as First Name - Last Name. The same goes for eMClient. The problem may be how you “file” the contact name. Sometimes I see FirstName, LastName and also LastName, FirstName. Sometimes with, sometimes without comma.
Any ideas on this, how to resolve the synchronization problem?
Thanks, and regards,
Danker
