Hi to the community,
I am a new eM Client user and have downloaded the app for android and also for my desktop. I have integrated my account from “mailbox.org” on both applications.
I would need support in how to synchronize the settings between the app and the desktop version. At this point in time, they are different. Also the “tags” are different. I have tagged some e-mails with a new tag and I don’t see the tag as well as the tagged e-mails in the desktop version.
So, it is on purpose that settings are different in both applications or can I syncrhonize the settings?
Thanks a lot,
Patrizio
If you are happy with your eM Client desktop setup and you have an IMAP, Exchange, Office 365 or iCloud account setup. then suggest on your mobile app, go to “Menu / Settings” and remove everything in your mobile app” so it’s like new.
Then on the desktop go to “Menu / Tools / QR Export” and select all the options you want and then at the end of the export wizard you will see a QR code appear.
Then on the mobile app press “Menu / Settings / Import-Export” and press “Import via QR code” and scan the QR code on your desktop. That will then automatically setup the mobile the same.
Re: Synching tabs between desktop & mobile.
eM Client will sync tags if your server is supported currently with Gmail, IceWarp, Exchange, Dovecot, and Imageway accounts”.
