The Sync2eM instructions for Android do not match Droid Bionic. Bionic is requiring the following: username (text field), password (text field), email address (text field), server (text field), use secure connection (yes/no), verify certificate (yes/no). ALL FIELDS ARE REQUIRED BY BIONIC.
Can someone please provide sample info and format?
I am presently getting message, “login to the account failed, please try again.”
If you followed instructions at http://www.emclient.com/sync2em, section Supported
devices/Android, it should synchronize without problems. Are you sure that you have any items at your Sync2eM account (check it through e.g. webmail or eM Client)?
