I setup a caldav connection to a SOGo email server, which worked well for about two days.
Now, it does not write the eM Client calendar entries to the Sogo calendar anymore. Any ideas about how to solve this?
The error is as follows below:
“MailClient.Accounts.ConnectionException: The character set provided in ContentType is invalid. Cannot read content as string using an invalid character set.”
here the complete protocol
(sorry, it’s in german…)
19:19:58 cal HM CalDAV / CardDAV Die Elemente werde hochgeladen: Fertig
19:19:58 cal HM [CalDAV / CardDAV] MailClient.Accounts.ConnectionException: The character set provided in ContentType is invalid. Cannot read content as string using an invalid character set.
—> System.InvalidOperationException: The character set provided in ContentType is invalid. Cannot read content as string using an invalid character set.
—> System.ArgumentException: ‘utf8’ is not a supported encoding name. For information on defining a custom encoding, see the documentation for the Encoding.RegisterProvider method. (Parameter ‘name’)
at System.Text.EncodingTable.InternalGetCodePageFromName(String name)
at System.Text.EncodingTable.GetCodePageFromName(String name)
at System.Text.Encoding.GetEncoding(String name)
at System.Net.Http.HttpContent.ReadBufferAsString(ArraySegment1 buffer, HttpContentHeaders headers) --- End of inner exception stack trace --- at System.Net.Http.HttpContent.ReadBufferAsString(ArraySegment1 buffer, HttpContentHeaders headers)
at System.Net.Http.HttpContent.ReadBufferedContentAsString()
at System.Net.Http.HttpContent.<>c.b__36_0(HttpContent s)
at System.Net.Http.HttpContent.WaitAndReturnAsync[TState,TResult](Task waitTask, TState state, Func2 returnFunc) at MailClient.Protocols.Common.HttpClientLoggingHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, Boolean async, Boolean emitTelemetryStartStop, CancellationToken cancellationToken) at MailClient.Protocols.CalDav.ProtocolCommands.Connector.RunCommand(CalDavAccount account, ICommand command, CancellationToken cancellationToken) --- End of inner exception stack trace --- at MailClient.Protocols.CalDav.ProtocolCommands.Connector.RunCommand(CalDavAccount account, ICommand command, CancellationToken cancellationToken) at MailClient.Protocols.CalDav.Synchronizer.UploadCommand1.GetResource(Uri uri, CancellationToken cancellationToken, Action1 successAction, Action1 failureAction)
at MailClient.Protocols.CalDav.Synchronizer.UploadCommand1.ResolvePreconditionFailed(TStorageItem item, Uri uploadUri) at MailClient.Protocols.CalDav.Synchronizer.UploadCommand1.Execute(WorkerStatus status)
EnqueuedStackTrace =
at MailClient.Protocols.CalDav.Synchronizer.ItemSynchronizer1.ResynchronizeUploadAndCopy(Folder folder) at MailClient.Protocols.CalDav.Synchronizer.ItemSynchronizer1.ResynchronizeUploadAndCopy(Folder folder)
at MailClient.Protocols.CalDav.Synchronizer.GoOnline()
at MailClient.Protocols.CalDav.CalDavAccount.GoOnlineInt()
at MailClient.Protocols.Common.AccountBase.ChangeOnlineState(Boolean online, OfflineReason offlineReason)
at MailClient.Protocols.Common.AccountBase.GoOnline()
at MailClient.Protocols.CalDav.CalDavAccount.Synchronize(SynchronizationPriority priority)
at MailClient.Accounts.BindingAccountBase.Receive()
at MailClient.Accounts.AccountManager.ReceiveAllInternal()
at MailClient.Accounts.AccountManager.SendAndReceiveAll()
at MailClient.UI.Forms.formMain.sendReceiveAll()
at MailClient.UI.Forms.formMain.menuItem_SendAndReceiveAll_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at MailClient.Common.UI.Controls.ContextMenuStripEx.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
at Interop.User32.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.Interop.Mso.IMsoComponentManager.FPushMessageLoop(UIntPtr dwComponentID, msoloop uReason, Void* pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(msoloop reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(msoloop reason, ApplicationContext context)
at MailClient.Program.<>c.b__173_1()
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor, Boolean wrapExceptions)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at System.Delegate.DynamicInvoke(Object[] args)
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at System.Windows.Forms.Form.WndProc(Message& m)
at MailClient.Common.UI.Forms.BaseForm.WndProc(Message& m)
at Xilium.CefGlue.Interop.libcef.run_message_loop()
at MailClient.Program.Main(String[] args)
