Sync Fehler beim hochladen von .ics Datei
beim importieren von ics Datei bekomme ich eine Sync Fehler und er lädt die Termine nicht rein.
That could happen if the Calendar folder you selected to import into is eg: “Read Only”.
Or could happen if the .ics Calendar file is eg: “Corrupted in some way.”
So first check that you have clicked “Calendar” under your email account “when you select a folder” to import into as in the below Gmail account example.
If you have already done that, then try “exporting your .ics calendar file again” from your other calendar, and then reimport it again into eM Client.
If still won’t import / sync, then could be your eM Client version might need updating. So update then “what version of eM Client you have” and also “if you have Windows or Mac” & OS ver.
Thank you very much for your quick response. But none of the problems you wrote about persist. As soon as I import the file I get a sync error and can hardly ignore it.
What version of eM Client do you have, and do you have Windows or Mac ?
Windows and the latest update is installed
Ok then as you have the latest eM Client version and rexporting your .ics file and reimporting your .ics file still won’t work, then sounds like something to do with the specific exchange mail account.
Sry I carn’t help you further. Others on this forum maybe able to assist you further.
I can only suggest if you have a paid active Pro or Personal version go to the VIP Support page and login and lodge a support ticket.
Ok, that said, however, thank you for your support! Could you help us get the list out of the system? We always encounter the following problem when we open the eClient.
To get rid of those errors everytime eM Client starts (untill you find out why the .ics file will not import and sync properly) would be to eg: go to “Menu / Accounts” and “remove and readd your account” as new again which should then just be back to the way it was prior to importing.
Or if you have been making regular eM Client backups either automatically via the Settings or manually via the menu, then try restoring a recent backup when you know it was working ok via “Menu / File / Restore” & see how that goes.
