I get a background intermittent noise of connection problems with my email server (gmail). The problem appears to intermittent and does not interfere with the performance of the email client. Unsure as the whether this is an eM client problem or intermittent problems with gmail (such as temporary overload). In any case the continual warning messages which need to be dismissed are far more aggravating than the intermittent connection problem. Is there anyway to suppress the warnings so that they do not need to be individually dismissed. I really don’t need to see that there was a missed connection attempt at 2 in the morning when i start my day.
Hi, you can disable the showing of the error messages in Settings, go to Tools > Settings, and uncheck the option “Show window when an error occurs”,
however this will disable all errors from showing.
Hope this helps,
