Suggestion for setting "default account"
I’m using eM at different customers (with multiple Exchange accounts).
It would be very convenient if I could easily select the default mail account for the day.
Hello Aniel,
you can set the default mail account in the Tools>Accounts section.
Just choose the correct account and click the ‘Set as default’ button.
Hi Olivia,
Thank you for your reply.
But my request wasn’t clear. I’m already using the way you described to change my default mail account. But was hoping for a toolbar feature, or shortkey.
For example:
Ctrl+Shift+1 = Google default
Ctrl+Shift+2 = company-account default
Or a toolbar solution. So it’s easier to select.
