I purchased two licenses for my business. I was using Thunderbird until now.
I sometimes work from home. At home I still have Thunderbird. I realized that the subfolders created with Em Client are not all visible from Thunberbird.
Is this normal? do you have a solution for this situation?
It depends on how the account is setup, and where you are creating the folders.
Any folders you create in Local Folders (below your account folders) won’t be synced. They exist only in eM Client.
If you are creating the folders in the account folders, if the account is setup as POP3, it won’t sync those with the server. POP3 only gets new messages from the Inbox, it doesn’t sync folders or messages with the server. But if the account is setup as IMAP or Exchange in both applications, whatever you do in the account folders one will be visible in the other one as well.
