Issue Description
This is a persistent visual glitch I’ve been experiencing with emClient. As you know, when you click on an email, it opens up with a fade in effect, which is a nice touch. However, the fade animation of the background almost always stutters.
Recording of Issue: 2023-12-07 13-53-09.mp4 | Storj
In the above video, if you focus on the background, you’ll notice the stuttering.
Expected Behavior
The ideal scenario would be for all visual transitions, including the fade-in effect when opening emails, to be smooth.
It is natural to think this might be an issue with my monitor or graphics drivers. However I don’t ever have this problem with other apps. I would be willing to disable the fade in effect to avoid this issue, however I don’t think there is an option in the settings for it.
Thank you for your support.
