From the emClient log, it seems it uses a strange mixture:
[SMTP] MailClient.Accounts.SocketException: Connection failed due to the following reason:
“A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. [::ffff:144.76.ggg.hhh]:25”
Webdav and IMAP connections to the same server work.
As long as your IP and DNS is valid I wouldn’t think it would make any difference when sending mail using either a IPV6 or IPV4 connection.
You can have issues if the eg: SMTP Server Settings “are incorrect in the mail client” or “the SMTP port is blocked” in some way.
So update what your eM Client “SMTP server address” , “Server Port” and “Security policy” are, so we can check those. Also what SMTP mail server do you send through.
Next if you are running any eg: Optionally installed Firewall / Security program, or Optionally installed Antivirus programs or VPN, try completely disabling those to test incase of interference.
If you are using POP account for sending and Port 25 is blocked, you can alt use the secure SMTP ports 465 or 587 as per @Gary advised below in another thread.
The port and security policy combinations are very specific:
SMTP
