The option to display images at the top of a mail no longer appears and images are always loaded. How can I stop them? (Under privacy, block unsafe content is checked.)
I’m running version 6.0.23181.0 on Windows 7 64bit
Hello Terry,
if you have the blocking option checked, the pictures shouldn’t load automatically. Does it happen for all your emails? Be sure to take a look at the ‘Show whitelist’ option under the Privacy section and Clear it if necessary.
Best regards,
Hello Olivia
I cleared the whitelist and I’ve got back the option to display pictures for each mail. Problem solved and many thanks.
Best wishes
Terry
