I am having problem when the app is starting, its saying some sql lite error and its auto closing.
System.Data.SQLite.SQLiteException: The database disk image is malformed
at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
at System.Data.SQLite.SQLiteCommand.BuildNextCommand()
at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at System.Data.SQLite.SQLiteConnection.Open()
at DbRepair.DbTools.OpenConnection(String fileName)
at DbRepair.Form1.CheckCorruption()
at DbRepair.Form1.Check(Object state)
If the application is unsuccessful I’m afraid you won’t be able to restore the original database data without an existing application backup. To create a new database that would allow you to synchronize your items with the server again, navigate to your Roaming folder in your local folder/App Data/Roaming and rename or remove the current eM client database folder.
Reopen the application and eM Client should automatically create a new database allowing you to setup your accounts from scratch.
