I have raised this issue before in July 2024 but never had a reply.
It is really very very annoying that when you save and close spellcheck, it randomly increases the paragraph spacing of either all emails in the thread, or sometimes only the email you are writing or sometimes only the other emails in the thread, not the email you are working on.
It does not happen every time. The spacing increases by about a paragraph and a half. The thread then takes up much more space and looks very untidy. To correct it you have to go back and re-space every wrong paragraph.
I have not been able to work out what triggers the error. Sorry. Others have had the same error.
PLEASE PLEASE please could the software backroom boys look at this ASAP and correct this very annoying error which is spoiling what is otherwise an excellent and very reliable product.
Thank you very much.
I know you most likely provided this in July. Can provided what OS, version of eM Client you are using? Also do you use any 3rd party products such as Grammarly?
Hello
I have a recent Acer desktop PC running Windows 11 version 24H2. I had the same problem with version 23H2 and possibly the one before that. eMClient version 10.1.4588 (f11e2ab) - I have automatic updates on and always update as soon as a new version is available.
I’m not quite sure what you mean by 3rd party products, but have never used Grammarly and am not aware of what it does. I just use the fonts available in eMClient Segoe UI 12 and other things available on the toolbar. I use spellchecker a lot as I am a two finger visual typist.
Hello Idreeder and everyone else.
I gave you the requested information back in Feb. I’m still using the same PC with Windows 11 which is regularly and automatically updated. eM Client is also automatically updated, so I am probably on a later version now than the one previously mentioned. Nothing else new.
I am still having the same problem, but it seems less often. It is still just as annoying when it happens. Is there anyone listening out there who might be able to solve this issue??
Many thanks and a Happy Easter to all. Best wishes Bruce HS
