There is no point in dealing with the complete list of languages for the spell checking options in the email window. It should be configurable what languages you want to see from the email options. Even more, it should be possible to uninstall any language.
Not all languages are listed there; just a few to get users started.
If you want to remove any of them, you can. You will find the files in C:\Program Files (x86)\eM Client\Dictionaries\
Oh, you’re on a Mac.
The spell-checking is offered by macOS not eM Client. You’ll need to see if you can disable them in your OS.
I add my opinion to this subject, as it seems adecuate. Sorry if it’s not!
As one user said, remove unwanted languages from the Diccionttary folder. I did it, and restarted EM Client. Still I get a list that’s more than I want. How to remove languages? (Windows11, just in case)
I have added extra languages (bravo!) but cannot remove 2 (French and Czech)
Thanks!
