After performing a spell check, words which i had ‘Replaced’ remain unchanged. A broken spell-checker makes your product completely useless for professionals.
Sometimes it works. Sometimes it doesn’t. After clicking ‘Replace’ or ‘Replace all’ on misspelled words, after you close the spell checker, the words remain uncorrected.
what version of eM Client are you using? I tried to replicate the issue, but have no issues with the functionality of spell check.
What you’re describing, does it replace any of the words or does the message stay unchanged?
I noticed problems with Spell Check. Here is what happens.
If I see a word spelled wrong (underline in red), I hit F7 which brings up the spell check. Going through the document until I get to the word, and replace it with the correct spelling.
Sometimes when I hit the Red X the word I replaced disappears completely.
Is closing the window with the Red X not the correct procedure. I don’t want to spell check the whole email if I am replying to someone. I don’t want to spell check their replies.
Hello Barbara as others have suggested this really should work on right click, and I’m also getting suggestions for this word using eM Client, can you please make a screenshot of your spell check settings from Tools > Settings > General > Spell Check.
Hello again, glad it works, please make sure to let us know if you come across any other issues or questions about the application, we’ll be happy to help.
Great! Note to developers-- seems like Barbara’s trouble shows that highlighting the word should intuitively give same spell options on right click? Thx
Hello Johny, are you having issues with this as well?
Barbara, can you please check what version of the .NET framework you have installed on your computer, you should be able to find the installed release number in the list of installed programs under your control panel.
I’m really not having any issues showing the suggested corrections on right click using any of the available directories, as you can see on the screenshot, please check the licensing number and send me an email to [email protected] with a reference link to this forum topic, we might need to exchange some private information.
The automatic spell check does not work in my em client.
All the settings have been enabled, and I have changed the language to English and back to default.
Nothing works.
I would expect the incorrect spelt words to be underlined in red. However, the red lines do not pop up and I have sent a few emails now with spelling mistakes.
Is this a problem that can be fixed?
Else I will have to go over to another email client.
