Speed up open/load time
This is no biggie here but I was just wondering if there is a way to speed up the time it takes for eM Client to open? I have been using an older version of Outlook 2007 which opens in less than one second; eM Client takes much longer. I am only interested in the Mail portion (no Calendar, Tasks, Notes, etc.) if that would shorten the load time. I’m running this as a POP3 account on a Win10 machine. Any suggestions would be appreciated.
Thanks,
Steve K.
How long does eM Client take to open ?
Well Outlook is historically known (not all the versions work like this) that it is preinitiated during the Windows startup and when started by user action it basically only shows its window. This approach optically speeds up the startup process a lot. We’ve decided not to do that, as the consequence of this is slower Windows startup and memomry used even the app is not fully running. Not sure if this is exactly the case of your Outlook, but it might be because 1 second is too good to be true.
However we know the startup time should be improved as well and we are working on that. Probably the 64bit and ARM version (in version 11) should help with that.
