I can’t see sort order applied to given column. ↑ ↓.
This is because the arrow disappears when you make the column narrow, which is often case for laptops.
joeves 21 mayo 2026 :: 0908hrs (UTC +0100)
Hey@maslana
I use “messages on right” message below works the same
Right click in any space between columns to show as below image.
skybat
¡Buena suerte!
Thanks, but I know how to sort columns. I just want to see and know if the current sort is ascending or descending.
joeves 21 mayo 2026 :: 1035hrs (UTC +0100)
Hey@maslana
Simply place the cursor over the word “sort” to show
the options you want & a second sort option
skybat
¡Buena suerte!
