Would it be possible for the “sort by…” field folders to be emboldened when they contain unread emails? This would be very helpful especially when searching collapsed groups folders.
Hi Tom, not completely sure what exactly are you referring to, but if you’d like to see folders in the left sidebar that contain unread messages in bold, this is unfortunately not possible in eM Client.
We’ll consider adding the feature to future releases.
Are you using smart folders? You can use unread smart folder to quickly access all your unread email, and see the unread count on top of the left sidebar.
Hope this helps,
