Software loads, but won't display, only icon in task bar and small window with cursor over icon
Emclient was working fine in my Windows 11, but now will not open to display, it fully loads, even allows emails to be sent and received if I right click on task bar icon which also shows a small picture with cursor over icon, but can’t get it to open. I have tried uninstalling Norton security suite 360 to no avail and uninstalling emclient and then reinstalling. Same thing happens, loads, but can’t view. Everything appears to be functioning, but something is interfering with enabling me to display it. Any suggestions? Please help, much appreciate it.
Tom
Probably it is open on another screen.
Hover your mouse over the taskbar icon, and right-click in the thumbnail that appears. Choose MOVE and use the keyboard arrow keys to bring it back on-screen.
Gary, thank you so much, I figured it was something simple and it was! Thanks again!!!
