Good morning,
Coming back to Windows after years on the Mac, Outlook is not cutting it. I need a unified Inbox across multiple mailboxes.
eMClient sure seems right up the alley with what I’m looking for. It checks off so many checkboxes of what I need and am looking for, and I was about to plunk down the lifetime upgrade + 2 device fee but then it seems its true colors began to be revealed.
eMClient feels unfinished. Things that should be simple and included in a modern-day email client are either not there or incomplete. Surely I am missing something. Here are my problems:
- Problem: Rules to move messages from Inbox to another folder on gmail do not remove the Inbox label, effectively leaving them in the inbox too.
- Impact: The inbox on my mobile device is filled with messages that should be stored in other folders, NOT the inbox.
- Cause: As far as I can tell, the rules add the label for the new folder (an annoyance of how gmail does “folders”) but never removes Inbox. This effectively makes the “move” rule a “copy” rule.
- Workaround: Manually select every message that comes in that has both Inbox and the desired folder labels, right click on the Inbox label, and select remove tag.
- Comments: This is unworkable. I receive numerous automated messages from various tools and monitoring devices for my work and if they are not filtered to their desired folders, real messages can get lost in the noise. Are there other options to do this? Yes, but I shouldn’t have to. Email filtering, automated rules, etc. works fine. Yes, I have these client side and not on gmail for a reason, though if I stick with eMClient it is clear I won’t be able to keep these client side.
- Problem: Rule editor will not let you copy an existing rule to build a new rule from it.
- Impact: If you need to create multiple rules that have similar elements, you are not able to create the first rule and then duplicate it, making it much easier/faster to create multiple similar rules.
- Cause: This is how the rule editor is designed. Or the rule editor is not finished/incomplete. I do not know which.
- Workaround: Thanks to someone here suggesting exporting the rules to XML, I was able to export my rules to XML and then edit the XML to create all the extra rules I needed and then import the XML back into eMClient and it worked. Mostly. It did not retain the order of the rules per the XML. Also, tip - importing the rules is additive, not a replacement, so before importing the rules back make sure to remove rules that already exist from the XML.
- Comments: At least the work around worked. It did what I needed and I got part of the way there. Problem is, see problem #1. Rules don’t actually work for gmail. This includes rules edited by the editor and rules imported.
- Problem: Rule editor does not permit selecting multiple rules to do things.
- Impact: If you need to apply multiple rules manually, you have to do this one at a time. You are not able to select multiple rules and apply (or delete) them. Need to apply 30+ rules? Click each rule, one at a time, click Apply, select Inbox, then click Run, and wait. This leads to the next issue, see problem #4.
- Cause: Same as problem #2 - the rules functionality feels incomplete.
- Workaround: None, apply rules one at a time, feeling your frustration growing each time…
- Comments: None needed. This is just brain-dead not being able to manually select and apply several rules at once.
- Problem: Applying rules manually can take a LONG time for each rule with gmail.
- Impact: I applied one rule manually, I have 30ish more to do after this. I started the first rule several minutes ago, approximately 10-15 minutes ago, it is now up to 3,220 out of 6,495. Not quite to the halfway point. I’m watching the Operations window and I can see it updating All Mail and syncing All Mail periodically. Needless to say I won’t be applying the other rules manually and I am very unhappy about this one. And this leads to problem #5 too.
- Cause: Not sure, it seems to be the way in which eMClient implements interacting with gmail and always syncing the All Mail folder. If you have thousands of messages it gets bogged down badly. Even after letting it sync and download all the messages for offline use to speed things up. Yes, and attachments too.
- Workaround: Suffer. I am on a fairly fast connection, 600 down, 20 up, and on an internal network faster than my internet connection. It shouldn’t take this long. Especially, as i mentioned earlier, all the messages are downloaded, including attachments, for offline use and searching. I also waited until the main sync finished and all messages should be downloaded before trying to manually apply the rule. In short, no workaround seems possible. You just suffer.
- Comments: Unacceptable. See problem #5 too.
- Problem: The rules window is MODAL! Seriously?!??
- Impact: Applying a rule that takes 20+ minutes to run (and counting btw), you get a progress bar over the rules window. Because rules is modal you can not switch back to eMClient to continue reading mail while the rule is applying. The mail app only lets you do one thing at a time - you can either use the mail client or edit/manually apply rules, but not both. Further, when editing rules, you are not able to change to different messages or views in order to better see the criteria you need to enter into the rule. Say you want to confirm some string, you have to close the rule editor, open the message, then open the rule editor again. Moving to another message? Close the rule editor, open the next message, then open the rule editor again.
- Cause: It had to be designed this way. This was not accidental or unintentional.
- Workaround: No mail for you! at least not while you are editing rules or applying rules manually.
- Comments: Do I really need to say anything?
For context, the machine I’m on is a Dell XPS 17, 6 core i7 processor, 64 gig ram, and SSD drives. The internet connection is 600 down and 20 up (not as fast as I’d like, or as fast as fiber, but it gets the job done). The local network is either gig eth wired or 5 gig wireless with 800 - 1200 typical performance, both faster than the internet connection. Also, the messages have all been downloaded. I also waited until I confirmed the sync operation had finished downloading everything before manually applying rules. The slowness is not the machine, the drives, the internet connection, or having to apply rules to remote messages because they weren’t downloaded – all things I’ve seen blamed for other people reporting slow rule application performance.
It has now been about 18 minutes since I wrote the part about rule speed. The progress bar has moved to 3,440. It’s advanced from 3,220, or 220 units, assuming messages, in almost 20 minutes. That speed, 18 minutes for 220 messages, averages out to 12.2 messages per minute. At this rate, this one rule will take another 4 hours and 10 minutes (roughly) to finish. I won’t be able to let it finish because I actually need to use the mail client, and in order to do that I have to cancel the rule in order to close the modal rule window and be able to use the mail client again.
If anyone knows what is going on here, and can offer suggestions on how to correct these issues, or even workarounds that would take the pain away, I’d love to hear it. Sadly, I fear my weekend will be partially spent trying to get another email client set up and all the mail downloaded into it, as I have to have email working smoothly for work. Please prove me wrong. There are other things about eMClient that I really like, and I’d rather not keep trying other programs if these pain points can be managed.
I also haven’t started trying to use the calendar yet. Not sure what I’ll find there, given what I’ve found here…
Thanks,
Greg
