I have given up eMClient after many happy years. I have used weeks to try to connect SMPT… I have been programming for decades, and wonder why eMClient doesnt have a manual connection option to servers. Look at SPIKE, it took secounds to connect to servers. Fill in server names, ports, username and password… Press Connect… and like magic, you are connected!
I am not able to connect SMTP when setting to a new mail accont. My servers name is smtp.altibox.no. The port for this server is 465. Security should force tsl/ssl.
14:41:19 xxxx IMAP Synkroniserer mappe’/Innboks’
14:41:19 xxxx IMAP Laster ned meldinger: For mappe /Innboks
14:42:30 xxxx SMTP Kobler til: [email protected]
14:42:30 xxxx SMTP Tilkoblet: [email protected]
14:42:30 xxxx.no SMTP Sender meldinger
14:42:30 xxxx SMTP Sender meldinger: Mottakeradresse ‘xxxx’ ble ikke godtatt av følgende årsak:
"5.5.6 You are not allowed to send emails from this service
14:42:30 xxxx [SMTP] MailClient.Storage.Application.ItemOperationException: Kan ikke sende melding (Sending email “a” failed with error: E-post mottaker ble ikke godtatt av server)
This is an error from your email provider’s server.
You will need to delete the message which you will find in the Local Folder Outbox. If Local Folders are not visible below your other folders, you can enable them by selecting Menu > Settings > General > General > Show Local Folders. Click on Save & Close to save the setting.
Then contact your email provider because it is not clear if they are saying the address is not accepted, or you are not allowed to send messages from your account. Maybe something lost in translation.
I have contacted the provider. They say:we can not help with you with eMClient. Contact them. He he.
And whatever other client I try, they connect in a second. He he.
Garry… I found a work around for the sertificare error in smtp.altibox.no. I used the smtp in gmail. I had to create a new app password in gmail, Now I am able to send elails from eMClient as before. Without yor help, I wold have ditch this client. Thanks so much!!!
