My eM Client will not connect with IMAP or SMTP, but works fine with POP3. I have two e-mail accounts (mail.kronen.lt and mail.jankrogh.com) at weblishtech.no. Passwords and addresses are checked and should work.
Also I have checked if there could be any mail shields, but cannot find any. I use Advanced Systemcare 6.2 PRO and Windows Firewall. Both programs were turned off.
12:30:[email protected] [POP3] Kobler til: Til [email protected]
12:30:01 [email protected] [SMTP] Kobler til: Til [email protected]
12:30:01 [email protected] [POP3] Tilkoblet: Til [email protected]
12:30:02 [email protected] [POP3] Laster ned meldinger: Fra [email protected]
12:30:02 [email protected] [POP3] Frakoblet: Fra [email protected]
12:30:02 [email protected] [POP3] Frakoblet: Utført
12:30:05 [email protected] [SMTP] MailExceptions.LoginException: Godkjenningen mislyktes grunnet:
12:30:05 "Invalid Username or Password
12:30:05 "
12:30:05 at MailClient.Smtp.SmtpSendCommand.Authenticate(WorkerStatus status)
12:30:05 at MailClient.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
12:30:05 at MailClient.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
12:30:05 at MailClient.Commands.Command.Process(WorkerStatus status)
12:30:05 [email protected] [POP3] Kobler til: Til [email protected]
12:30:05 MailExceptions.Exception: Kan ikke åpne TLS/SSL-sesjon
12:30:05 at MailClient.Pop3.Pop3ReceiveCommand.Connect(WorkerStatus status)
12:30:05 at MailClient.Pop3.Pop3ReceiveCommand.Execute(WorkerStatus status)
