I have some weird issue to sending emails over 587 port.
19:18:03 XX@XXXX.eu [SMTP] MailClient.Accounts.SocketException: Sending messages failed due to the following reason:
19:18:03 “The decryption operation failed, see inner exception.”
19:18:03 at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
19:18:03 at MailClient.Commands.Command.Process(WorkerStatus status)
It pops out occasionally, sometimes it’s working, but sometimes not. Tried with some config changes, disabled FW/AV, all the same.
First thing to check is that you have the correct security policy for port 587. Change that to Force usage of SSL/TLS and see if there is any difference.
Hi, did all the settings available (SSL/TLS, Force) and when it’s not working it’s not working. Legacy throws different error (I guess they do not support it). Is there any chance to increase logging output in emClient?
Port 587 is the most secure, and port 465 should no longer be used for SMTP though I think many providers are just to lazy or scared to remove the port from their servers. ;-)
You did not say who the email provider is. Maybe it is a know issue with them.
I’ve checked all mentioned combination of ports with them, right now it’s working with 587 Use SSL/TLS if available. Then, out of no reason, it will stop working and the error above will occour.
telnet/openssl both works when it can’t send, so network connection to their server is established…
Yes, this is the eM Client forum, but it is a user supported forum. As per the agreement you accepted when installing and registering a Free License, support from the company is not to be expected here. Employees do comment occasionally on major issues, by it is not guaranteed.
It is unlikely any user commenting on this forum will have the kind of information you require, so if you need specific technical information, it will be better to write to eM Client Inc. for details. If you have a Pro License, you can also open a support ticket.
Yeah, no problem, we installed it and we want to go pro, but w/o this issues if they are happening on client side. We want to exclude client from this.
It’s happening today too:
17:28:33 xxx1@ [SMTP] Sending messages
17:28:33 xxx2@ [SMTP] MailClient.Accounts.SocketException: Sending messages failed due to the following reason:
17:28:33 “The decryption operation failed, see inner exception.”
17:28:33 at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
17:28:33 at MailClient.Commands.Command.Process(WorkerStatus status)
17:28:33 xxx1@[SMTP] MailClient.Accounts.SocketException: Sending messages failed due to the following reason:
17:28:33 “Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.”
I’ve put “Force SSL…”, the result is the same.
Telnet is working, so I think client has connection with the server, so I guess this isn’t because of FW/AV (I can disable them and test again, but I already did it several times before).
