SMTP Connection Failed - Operations
When starting eM Client, I get a popup box which says:
“[IMAP] An attempt to connect to ****** failed. This could be caused by temporary server unavailability or incorrect settings.”
eM Client version 9.2.2093 (6d2fe6b)
lunes 09 octubre 2023 :: 0853hrs (UTC +0100)
If you expect any help you will need to give details of your IMAP setup
and your service provider.
Have you actually checked to see if the server is active?
skybat
¡Los mejores desde Valencia y mantente a salvo!
Host: imap.gmail.com
Port: 993
Host: smtp.gmail.com
Port: 465
The server is active as I’m able to send & receive email via browser.
However, I’m able to send & receive email thru eM Client, but this error keeps popping up every time it refreshes.
lunes 09 octubre 2023 :: 1044hrs (UTC +0100)
You only provided partial settings, below is what you should have.
IMAP
Host imap.gmail.com
Port 993
Security policy SSL/TLS on special port (legacy)
SMTP
Host smtp.gmail.com
Port 465
skybat
Yes, following are the settings:
IMAP
Host imap.gmail.com
Port 993
SMTP
Host smtp.gmail.com
Port 465
@Vantage
Suggest to try SMTP Port 587 and force use of SSL/TLS
