Smooth Scrolling Issue on 120Hz Displays
Issue Description
The smooth scrolling feature does not seem to work in sync with the 120Hz refresh rate of my monitor. Specifically, when scrolling through an email thread, the scrolling appears to be locked at 60fps, rather than the expected 120fps. This creates a noticeably less smooth experience compared to what the hardware is capable of.
Expected Behavior
Ideally, the smooth scrolling should be fully compatible with higher refresh rate monitors, offering a seamless 120fps scrolling experience.
OS: Windows 11
miércoles 07 diciembre 2023 :: 1807hrs (UTC +0100)
Please explain:
where and how do you have smooth scrolling enabled?
the size and display setting of your monitor?
as far as I am aware the maximum refresh in Win 11 is 60Hz
what processor do you have?
how much RAM?
I have a high end 32" 4K UHD BenQ 120Hz monitor and do not experience any issue
I do NOT have smooth scrolling enabled
¡Buena suerte!
Alvaro Muñoz (skybat on holiday)
¡Los mejores desde Valencia y mantente a salvo!
Hi skybat,
Smooth scrolling is disabled on my computer. However the email view on eM Client seems to have it by default. When I am scrolling through a long thread of an e-mail conversation, it clearly smooth-scrolls, however the scrolling animation refresh speed seems to be on 60fps rather than 120fps. This is not a huge issue or anything, just something that always catches my eye, since I believe it should run faster than that in normal circumstances.
Display is 42" LG C1, running on 4K 120Hz.
Computer specs are Ryzen 7950X, 64GB RAM, RTX 4090
eM Client Version: 9.2.2157 (5b49542)
OS: Windows 11
