Is there any way I can turn off smart text select in the editor? As soon as I drag across (parts of) two words, both are selected in their entirety.
Thanks…Neil
Thanks…Neil
Hello Neil, I’m not completely sure what you’re referring to as Smart select feature, as far as I know, eM Client does not include anything like this feature.
OK, for a simple example if I type “…I nee dto” by mistake, as soon as I click to the right of the “d” and drag across it to the left, the whole " dto" is selected. I don’t want it to be: I want to drag left and select " dt" so I can retype “d t”.
