Slow Start from Pinned Taskbar Icon (From Closed to Tray)
I have minimize and close to tray enabled.
I’m on Windows 11, if this matters.
I have pinned the eM Client icon to the taskbar.
So, the problem is:
If I restore the app from the tray icon, it opens as fast as it should. Normal behavior.
But if I click the taskbar icon, it takes up to 4-5 seconds for the window to open. It’s like the app is trying to launch its second instance, but then realizes that it’s already open, and only then it restores its window.
Pretty annoying.
Thanks for your help.
sábado 17 agosto 2024 :: 1305hrs (UTC +0100)
Maybe there is a difference in terminology.
There is a Taskbar across the bottom of the screen
A System Tray to the bottom right of the screen
Using Win 11 Pro:
Starting from the Taskbar normally takes a few seconds dependant upon the specification/capability of your computer (a cold start)
Starting from the System Tray will be instant again dependant upon the specification/capability of your computer (already running in background)
So if this is what you are doing it is not eMC that is slow it is your computer.
¡Buena suerte!
Alvaro for skybat
Thanks for your trying to help.
I have an update to this, which was easier to upload as a video: https://youtu.be/bTNT5XWxBc8
So, something must have been fixed in build 10.0.3530.0.
