Used to have no problem but it seems since latest upgrade that the email headers arrive fine (using IMAP) but when i try and view the email I get a long time with a row of dots circulating. It can even give up and announce I am not on-line (but web browser proves I am and a few minutes pass and more headers arrive.
I have the same issue
Hello David, are you using any security software on your computer, that may have disabled the application’s ability to connect to the mail server? If so, can you please try to temporarily disable the software and check if the issue persists? This can unfortunately be caused when the server is not responding on time or when the connections gets terminated or times out.
If the issue persists, what mail service are you using with eM Client?
I have the same problem, but it applies mainly to my IMAP account (hotmail) and not to Exchange (UN account). If my firewall (COMODO) would be the cause, why did it not happen earlier, because I have the firewall for a long time and it also does not affect the Exchange account. I think there is another bug in the software that needs an urgent fix.
Hi Paul
1/ Like Ingoi says, nothing has changed in my security but I will try
2/ It happens at work & at home with different architecturs
3/ Using simple IMAP direct to ISP
