Silent install and setting Storage Location
I want to set up a process where I can silently install EM Client and set storage location. I have the process for doing the install how do I set the storage location without having to go into the Client and set it ?
miércoles 12 agosto 2026 :: 0809hrs (UTC +0100)
Hey @Highlandersword
Yes, you can do this though personally I would NOT advise this.
You can change Storage location by: Settings >General >Storage >follow instructions
Do NOT FORGET to save changes.
AND
1./ First make a Backup before any update (Menu >Backup) - VERY IMPORTANT
2./ To proceed, completely shot down eMC
3./ Download the relevant upgrade .msi installation file at below link:
(Release History | eM Client)
4./ Move file to Desktop if not already there
5./ Double click the .msi file and wait for installation to complete
6./ Disable option to:
Set eMC as default application (as upgrading should already be set - do manually if not)
Run on Windows start up (you can set this later if you want - we do not)
Launch eM Client
7./ Finish
Again this procedure has never failed for us.
skybat
¡Buena suerte!
Hablo español, luego portugués, inglés, francés, italiano y alemán
con conocimientos de varios otros idiomas incluidos griego y ruso
