No matter how many times I choose the bottom of the text as the signature position, it always places it on top of the text.
Settings > Mail > Templates and Signatures > Signature Position = After quoted text
In other words, when I write an e-mail, I enter the address of the receiver, type the subject and then press TAB, the cursor jumps directly under the signature. Whereas I want the signature to stay at the bottom, so the cursor have to jumps immediately over the signature. I don’t understand if this is a bug. I have another mail account. When I define a signature for it and select the bottom of the text as the signature position, I have no problem there.
Same for me too. When I insert signature on a fowarded message it appears before the body of any text I type at the very top of the message. If I delete the inserted signature, move the cursor to where I want the signature and then insert the signature then it appears in the correct position. Is this a known bug? Or is there a setting that can correct the problem so when inserted the signature appears at the current cursor position? Thank you.
This appears to work ok now when i tested with composing, replying or forwarding using the latest eM Client V10.0.3530 via the release history page, where “after typing a subject” i press Tab “and the cursor appears above the signature” using the (Before quoted text) in Settings.
