Some times when I reply to an email the signature does not show up correctly. Pictures, links etc are replaces by code. Most often it works as it should but when I reply to certain mails it does not work.
Wrong:
Correct:
Anyone has a fix for this?
Hi Henrik,
I believe the issue is in the format of your email being changed from HTML (which can view images and links) to Plain text, depending on what the original message’s formatting was.
Go to ‘Tools > Settings > Mail > Compose’ and in ‘Mail format > Mail format for reply’ choose “HTML” instead of “Autodetect from original message” and see if that fixes the issue.
Worked like a charm! Thank you!
