Showing 8 messages in Inbox when there are none.
Displaying 0 unread now, when I selected âMark All Messages as Read.â
I have âPrimaryâ and âOther.â
I selected âOtherâ and there were 3 messages.
How can I turn off Inbox Categories?
I right clicked the message list header and turned off the category tabs.
All seems well, now.
James
With version 10.0.3117 - and todays update to 3125,
new messages on my Outlook accounts will not be shown in the Inbox, but the counter shows e.g. +1,
when I see under Favorites Unread I can see these messages. Then I select âmark as readâ but wonât be shown up in Inbox. Also I did a repair 2 times which doesnât help.
I also miss other e-mails received in the past days which I can see on my outlook.com but not in eM Client.
Enclosed 3 screen shots from the Favorits/Unread ⌠which shows âInboxâ but are not in Inbox of the account, and one from outlook.com where you can see at least 2 emails not shown in eM client Inbox.
All Outlook accounts using AirSync and I can send e-mails.
Why isnât category ALL the default to avoid sitting another 2 hours where is the problem?
When you install or upgrade to version 10, you are asked how you want to use categories.
Whatever you choose there is what you will see in eM Client.
If you later want to customise and show others, you can do that.
Yes, after the update I got the wizard, thought I will read it later, but then I didnât feel very well and so I stopped and later in the evening I turned off the computer. I have Corona (the first time).
After a new start today I didnât receive the wizard anymore - however.
Thatâs why Iâve missed the details.
It makes no sense to show All as default. You either want to use Inbox categories and in that case you want to see just the important emails by default (Primary), thatâs the whole point behind that, or you donât want to use categories at all. Weâve really done a lot of a/b testing with that with users. It is a matter of choice for everybody, thatâs why weâve introduced this well described option in the initial wizard or when upgrading from older versions.
Now that I understand, it makes sense to have categories.
