Show marked emails in the agenda does not work for some accounts
Only “flagged emails” are displayed in the agenda for one email account. This is a Gmail account. For another Gmail account and accounts from other providers, “flagged emails” are not displayed. What can I do to solve the problem?
Hallo,
innerhalb der Agenda gibts Einstellungen (Zahnradsymbol). Und da ganz unten steht “Ordner wählen” Guck mal da, ob das Konto angehakt ist, von dem die markierten Emails fehlen. Wenn nein - anhaken - dann könnte es vielleicht funktionieren
Within the agenda there are settings (gear symbol). And at the bottom it says “Select folder” Check if the account from which the marked emails are missing is checked. If not - check it - then it might work
