I’d really love to see shortcuts to cycle between accounts and switch to specific accounts. I don’t see them in the shortcut settings.
Hello Naveed, unfortunately it is not possible to switch between accounts using a shortcut, but you can switch between the folders in the left pane, by selecting one of the folder and thus putting focus on that application pane, then you can use your keyboard to navigate through the folder list.
You can either use arrow keys to navigate one by one, or letters on your computer, to jump to the folder with the appropriate name.
